Front PTO removal, Massey Ferguson 65, and 200 loader
   / Front PTO removal, Massey Ferguson 65, and 200 loader #1
Jaron
Massey Ferguson 65, loader 200, backhoe 212
Hey does anyone have some tips on how to remove the front mounted PTO? It has three bolts holding the plate to the crank pulley and the shaft comes out the front frame and couples with a yolk and key way onto the hydraulic pump. Left hand thread? Don’t want to drop the front end if I don’t have to. I have to have a new one machined because the steering arm snapped the shaft by rubbing on it over and over.
   / Front PTO removal, Massey Ferguson 65, and 200 loader #2
LH threaded. Why machine when you can buy a new shaft?
So it’s done. Front end is out. It is a left hand thread. It’s possible to unthread it by sticking a pipe wrench on it while tractor is assembled but it turns the crank regardless of it being in gear. I unbolted the plate put it in a vice and used a pipe wrench with an extension bar.
Hopefully someone may find this thread useful
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
