Snow Front or rear mount snow blower??
   / Front or rear mount snow blower?? #1
WVnewbe
West Virginia
Kubota L5240
I have a 5240 with cab. I was thinking of adding a snow blower this year. Which would be the better fit for this tractor. I have a driveway about 1200 ft long.
   / Front or rear mount snow blower?? #2
Front mount for me.
   / Front or rear mount snow blower?? #3
Front is a whole lot better, but also a whole lot more money... I had a 4' rear blower on my TC18 - cost me $500 used. I bought a 5' front blower for my B3030 - cost me near $5,000 with all the gadgets - hitch, electric deflector, hydraulic rotator.
A good rear blower is ~$2,000 +/- depending on size & features.
   / Front or rear mount snow blower?? #4
My kubota 2782 front blower w/hydraulic chute rotator was $4400. That was 2 years ago. Its a beautiful implement, all the fine machine work on the components is very impressive, right down to the little rubber grease fitting covers on the main auger bearings.
   / Front or rear mount snow blower?? #5
I've had both but use a front mounted blower now. I never minded the rear mount but you can be a lot more precise with the front mount in close quarters. If the cost doesn't bother you go with the front mount.
   / Front or rear mount snow blower?? #6
WVnewbe said:
... I was thinking of adding a snow blower this year. Which would be the better fit for this tractor...
I recommend a new type of rear snowblower – it is referred to as the “pull type”, or the “reversed” or “inverted” snowblower. The reversed snowblower is easy and pleasant to operate compared to the conventional rear mounted 3pt design which I was using previously. The inverted design has the advantage of doubling as a type of boxblade to scrape a light snow fall away very quickly. I especially like the ability to use both the blower AND the loader options in winter. The inverted design works well, and there is no problem with packing the snow with the tires. I also like being able to drag the snow out of difficult spaces where blowing is not feasible.
   / Front or rear mount snow blower?? #7
Gotta go forwards! It's pricy because ya gotta add the lift, unlike the rear. But you can always add a broom or blade since you've already got the lift.:D
Here's my wife running ours:cool:
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2018 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2018 Ford F-550...
534 (A52708)
534 (A52708)
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
MILWAUKEE SAWZALL W/ CASE (A58374)
MILWAUKEE SAWZALL...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
