Front mount snowblower on a larger 5000 or 6000 series JD tractor
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #1
GreenTime
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I have a 2011 JD 2520 with Curtis Cab and front mount 54" blower and it works pretty good, just would like a factory cab. I am looking to upgrade to much larger tractor to use on a Woods RDX 90" finish mower. Does Deere offer a front mount snowblower for their 5000 and 6000 series utility tractors (not necessarily new tractors, would like to find a used one 15-20 yrs old)? If so, it is designed like the smaller ones with a front quick hitch? Any pics of front mount snowblower on a larger tractor would be great! Also would consider a Kubota if Deere does not offer this configuration. Thanks is advance!
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #2
You're talking about front 3pth and front pto? There are kits available for retrofit. If I remember right, they are in the $20000 range.
There are used tractors on the market equipped with it. Very rare in the US, almost standard in Europe.
For the blower, petty much any blower will fit.
I'd rather not go the front 3pt route. Would rather find a front mount design similar to the one I have on my JD 2520. Not sure if the 5000 and 6000 series tractors have front PTO for this application.
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #4
Visualizing a 90" finish mower behind a 6000 series tractor, that would make for a heavy mower.
For your listed uses a 3720 cab model might be a better bet for mowing and snow blowing.
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #5
Agree. I run an RM990 with 42 PTO hp and its more than enough.
I'd be shocked if anyone builds a front subframe mount for a snowblower to fit 5000 or 6000 series Deeres. The market for such an item would be in the single digits per year, if any.
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #6
Loftness probably makes a front mount kit that uses the rear PTO, I have one of their kits on our Kubota L3830 that came off of a larger (60ish HP IIRC) New Holland.
Aaron Z
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #7
Deere (Frontier) makes a front mount blower for their large-frame compacts, 4000 series that runs off a rear, 3pt mounted pto pump/hyd reservoir.
Quick hitch to the front loader.
No idea on cost but the 4066R with cab would make a pretty capable and comfortable "snow blower"!
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #8
Why is that? A front three point will have a higher range of lift height and higher weight capacity. Why the jump from a small tractor to the 5000 or 6000 series? Do you have other work for this tractor that warrants the size increase?
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #9
Evidently Yanmar is working on a hydraulic power pack to run a front blower that mounts to the loader arms...
All I've got is this "sneak peek" from Wranglerstar: Wranglerstar - Here is a picture of the PTO driven Hydro... | Facebook
Seems like a lot of trouble just to have a blower on the front, but I'm not spun around in the seat blowing snow all winter... ??
   / Front mount snowblower on a larger 5000 or 6000 series JD tractor #10
Snowing here at the moment. Probably have 5-6 inches to plow in the next hour or two. If you're interested; I can meet you at the airport with the keys to my tractor...
I'll do your chores for the next couple of months and you can do mine! (I have a rear blower. Also a good chiropractor on speed dial.)
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A57454)
New/Unused 72inch...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
Black Steel Diamond Plate (A55758)
Black Steel...
