Front loader will not raise unless rear lift is raised also
   / Front loader will not raise unless rear lift is raised also #1
goinesp
sage,ar
terraplane
I have a 30HP Terraplane tractor . I been having problems with front end loader raising but now I can't get it to up at all unless I work the lift on the back bucket at the same time then it goes up in a hurry. Tractor repair man told me it was probly the Spool valve bad for the loader so I replaced it with no change.
   / Front loader will not raise unless rear lift is raised also #2
:welcome:
I can't help you with this, but one post with the question is enough. You posted the same question three times within 11 minutes and 2 posts were in the same thread.
sorry I am new to the site and thought I needed to list messages in proper sections for help.
   / Front loader will not raise unless rear lift is raised also #4
Try deleting a double post or repeat post. You have a limited time to do so, maybe 24 hrs.
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
BOBCAT QUICK ATTACH HYD SOD LAYER (A51244)
BOBCAT QUICK...
