Front loader connection
/ Front loader connection #1
HankStains
Berry, France
Fordson Super Major, Massey 835-DS, Energic 521, John Deere 420, Case 580B CK
Can anyone tell me (or show me with a photo) how their front loader hydraulics connect to the tractor...I think mine is all wrong.
Ta..
Pete
/ Front loader connection #2
What tractor and loader? I don't know if they are similar enough for a "one size fits all" answer. If it's a B7500 and 302FEL, I can trace my lines out and tell you. Mine came with small dots of paint to "color code" the hoses to the valve body.
I took the advice of a poster here and went to Home Depot and got a bag of colored tyraps because the paint was kinda hard to see. Now all I have to do is get the tyraps on both halves of the QD couplings to match.................chim
/ Front loader connection #3
Just took my loader off tonight for the first time. B7610 LA352 FEL. My has plastic tabs and caps color coded on both the tractor & loader. I could take some pics of it if that's help.
/ Front loader connection #4
I beleive from his others posts that he is running a B7001.
Hi,
It is a B7001 and i think the loader is a LA301 with a two lever spool. I can show photos of the current setup if this will help.
Ta Pete
/ Front loader connection #6
What is all wrong about your front loader connections? Loader doesn't work? Loader works but the controls seem "backwards?" The hose hook up is a real mess?
On my Kubota and on rental tractors I've used, the controls work as follows:
Push control stick forward to lower bucket,
Pull back to lift bucket,
Push right to dump bucket, and
Pull left to roll back the bucket.
/ Front loader connection #7
Hello HankStains -
Here is a picture of the "color-coded" quick disconnects on my B7610 / LA352. The colors are as follows:
White / Yellow: Raise / Lower bucket
Blue / Red: Curl / Dump Bucket
The "functions" may be reversed - but the color pairs at least show the hydraulic connections for a specific function.
More pics on my website - link at bottom.
Hope this helps,
Dan
FEL Valves / Hoses
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
Hay Feeder (A65640)
Hay Feeder (A65640)
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
3145 (A63117)
3145 (A63117)
Spirit Electric Bicycle (A64127)
Spirit Electric...
