Front loader blade
   / Front loader blade #11
A "V" plow works well for opening a road, as it keeps pressure of the snow equal to both sides; therefore, not forcing the plowing vehicule off to one side.
That tractor mounted plow of yours is more like a scraper plow. Having the trip edge and angling cylinders would permit more flexibility.
But in any case, if you add "ears" on both sides so not to loose snow off the edges, you will not be able to tilt down your blade anymore, just like you have shown us in your pictures.
I never thought of that tilting issue after I added ears as you call them. Currently I leave a Ridge and then back up Ober it with the rear mount blower. Overall it is quite fast. I rarely use the blade to pull back but it does come in handy sometimes.
   / Front loader blade #13
It's really easy to bend the blade or loader arms without any trip springs. I was building a snow pusher and wanted to test the angle I had then SSQAset at. First thing it hit bent the plow badly.
The wear bar on my atv plow was 1/4" and I bent it pretty good with my 800# atv hitting the curb despite the trip springs. I replaced it with 3/16 because the piece I found was the right length/width in the drops section of the steel yard and I thought I'd be ok as long as I didn't ram the curb like what bent the first one. I ended up snagging the edge of a section of concrete on the neighbor's driveway and bent the new one before it ever cleared ours.
Plows take a lot of abuse.
   / Front loader blade #14
Those v blades Are awesome!!! Got one on my 79Ford 150. I was moving last winter and had a friend with a Duramax with the 7.5 blade and it only got Tho 20ft of 2ft deep snow and built a 10 pile of snow. My v blade could have gone thro that and more if the truck was running right
   / Front loader blade #15
I thought they were the best thing since sliced bread. But now I work at a institution with a large campus and they have two of the v-plows, one of them is a big one, and the guys that use them hate them. They mainly use them to clean parking lots, and they always leave a streak of snow in the middle. But what they hate the most is trying to use the v-plow like a regular flat plow at a angle. They say as you are driving through trying to throw snow to one side, that the snow will not pass over the "bump" in the middle of the plow. It sits there stagnated till it ends up as a big "snowball" and it suddenly rolls out the side of the plow.
I would think there should be methods of plowing to avoid this, but they have it set in their minds they do not like them.
   / Front loader blade #16
There is methods of avoiding it. But u still may have the problem. On mine my plow unit is old so i don't get the best angling. With any plow strait or v u will have problems but u just have too man up and use it
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
Round Bale Feeder with Skirt (A50515)
Round Bale Feeder...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
