Front laoder/bucket
   / Front laoder/bucket #1
Don in LA
South Louisiana
1967 Ford 3000, 42 HP Diesel, 2WD
I own a 1967 Ford 3000 diesel. I have found, via an advertisement, a front loader/bucket from a Ford 3500. I don't know the year. Is it likely that would fit on my machine? I'm not a mechanic and I am not sure what questions to ask the seller.
Thanks,
Don
   / Front laoder/bucket #3
Thanks,
Don
Not sure on the 3500 my 3000 has what looks to be the same as the 3400 series industrial.
From what I have seen the most quoted models on the 3000 are model 730 and 735 ford loaders.
The one I have has a front crankshaft driven Vickers vane pump that powers only the FEL gear pumps were also used -this style set up will give very fast lift and curl speeds that would embarrass some newer machines... the style that relies on the tractors 3 point pump will be MUCH slower. and also is not fully independent of 3 point operation. The other thing to consider is the 3000 has a lighter duty front adjustable axle than the industrial model - which with heavy use can be broken, although if treated with care or once reinforced seems to hold up ok.
my :2cents: and hope this helps
   / Front laoder/bucket #4
Thanks,
Don
There are two questions to ask. "What model loader?" And "does it come with the front pump?"
   / Front laoder/bucket #5
Actually thought of some more IF it is a front pump style does it come with these parts
1 the crankshaft drive coupler that bolts to the crank hub? have not seen this part for sale??
2 the splined drive shaft - like this?? 292222 Ford New Holland 10 38" 730 Hydraulic Pump Drive Shaft 13 Spline | eBay
3 the drive coupler assembly New C5NNN879A Ford New Holland Hydraulic Pump Hub 335 340 532 535 3400 4400 | eBay
4 the pump hub 291315 Ford New Holland Tractor Hydraulic Pump Hub 730 Loader w 13 Spline New | eBay
5 the complete valve assembly
6 the front mount plate for the pump
7 a working pump - these can run $700 + for the vickers style
I am sure i forgot something but this should give an idea of what all is needed- missing or non functional part costs can add $$ up fast...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2015 LINDE H80D FORKLIFT (A50854)
2015 LINDE H80D...
16ft Trailer (A50322)
BLAST SHIELD (A50854)
