Front Hydraulic snow blower slows down when warm
   / Front Hydraulic snow blower slows down when warm #1
buffdan
Buffalo Ny
Kubota B3030
My neighbor adapted a Sheyenne CT500 hydraulic snow blower to his NH Workmaster 40.
Using a used Prince 540rpm PTO pump, This snow blower was originally attached to a smaller Cabellas tractor.
He is using 5 gallon tank, new filter, new AW32 general purpose hydraulic fluid, Sheyenne original filter block with safety valve, new proper sized hoses.
When he first uses it, it blows snow quite well, after 15 minutes or so, the blower slows right down, even with minimal snow. I measured temperature at PTO pump, snow blower motor and its around 150 degrees.
We opened the Prince pump, it was very clean. Had some wear in chamber for main gear.
Overall the snow blower has limited use since original. (unsure of history of PTO pump)
Any ideas on what to check, replace, adjust?
Is AW32 correct, does fluid make/weight matter?
Thanks!
Dan
   / Front Hydraulic snow blower slows down when warm #2
Without flow meter
Or gauges it's just parts replacing
   / Front Hydraulic snow blower slows down when warm #3
AW32 is a very Light Hydraulic Oil especially @ 150F. Also a Cooler might be required for anything over around 140F
   / Front Hydraulic snow blower slows down when warm #4
Weird, I’ve been using my hydraulic blower for 10 years without a cooler. It uses 25 gallon reservoir though, so it doesn’t get very hot. It uses 22 weight hydraulic oil.
   / Front Hydraulic snow blower slows down when warm #5
Did you check the temperature of the motor, safety block, etc. if one component is getting hot quick under load that is the component that is by-passing oil.
Thanks for all the inputs, I appreciate it.
Have to try and eliminate pieces.
I have a pressure gauge, no flow meter.. Will do more testing, checking temps more closely
   / Front Hydraulic snow blower slows down when warm #7
You will need to load the blower so that it slows down for the heat test and or pressure test. Speed dropping is some component by-passing oil and not building pressure.
   / Front Hydraulic snow blower slows down when warm #8
Heat only a factor if one piece of the pie is doing it
Hydraulics in the desert run 220
Or more that's with coolers
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
