front hydraulic pump leak
/ front hydraulic pump leak #1
kubotab20
sw pa
kubota b20
I've got a Kubota b20 that has a small but persistent leak in the front hydraulic pump. I'm guessing the tractors 15 or so years old with between 1000 and 1600 hours on it. I've had it for 2 years and it runs strong. Only thing I've done is replace some hydraulic hoses and change the engine oil. What should I do about the leak? I was just gonna start taking the pump apart to check it out but I've never worked with hydraulics so I figured I should ask you guys about it.
/ front hydraulic pump leak #2
You first have to identify where the leak is comming from. Is it comming from a seal in the pump, hoses foing to the pump, hoses comming out of the pump, one of the fittings??
It could be just as simple as changing a hose.
Pics would be helpful too.
Thanks for the reply. I'll clean it up and run it for awhile to check that and then come back here.
Dan
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2019 Chevrolet Silverado 2500 Pickup Truck, VIN # 1GC1KREG4KF129755 (A65563)
2019 Chevrolet...
2022 EZ-GO ELITE...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Massey Ferguson 461 Tractor (A65579)
Massey Ferguson...
