front hydraulic pump leak
   / front hydraulic pump leak #1
kubotab20
sw pa
kubota b20
I've got a Kubota b20 that has a small but persistent leak in the front hydraulic pump. I'm guessing the tractors 15 or so years old with between 1000 and 1600 hours on it. I've had it for 2 years and it runs strong. Only thing I've done is replace some hydraulic hoses and change the engine oil. What should I do about the leak? I was just gonna start taking the pump apart to check it out but I've never worked with hydraulics so I figured I should ask you guys about it.
   / front hydraulic pump leak #2
You first have to identify where the leak is comming from. Is it comming from a seal in the pump, hoses foing to the pump, hoses comming out of the pump, one of the fittings??
It could be just as simple as changing a hose.
Pics would be helpful too.
Thanks for the reply. I'll clean it up and run it for awhile to check that and then come back here.
Dan
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
23311 (A51694)
23311 (A51694)
ALLIANCE 480/80R42 LOT NUMBER 54 (A53084)
ALLIANCE 480/80R42...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
