Front hydraulic couplings for grapple not releasing pressure
   / Front hydraulic couplings for grapple not releasing pressure #11
Yep James, uncoupling hot is the best protection if possible.
   / Front hydraulic couplings for grapple not releasing pressure #12
Remove the two quick connect hoses for the grapple, then try to reconnect...no-go. Pressure remains in (apparently) the grapple side.
Ok - Mea Culpa - I missed this part when I read it. :eek:
But I stand by my statement that it still could be he's not really reliving any pressure like he thinks IF he's using a Diverter or 3rd function valve and operating it with the power off.
Especially so if we assume (yea I know I'm already in the hole here for that) he is doing all this immediately as a trouble shooting series.
The grapple fully closed, power off, actuate the hydraulic lever to what I thought would relieve hydraulic pressure.
If so there's no time for thermal expansion / contraction in the grapple lines therefore another potential answer is that there is still residual pressure in the lines because he isn't relieving it like he expects he is.
I apologize if I came across as arguing or contradicting what you guys offered up. Just simply trying to trouble shoot & provide all possible options to look at. It's the old school medic in me. Differential Diagnosis - Throw every possible answer into the funnel and then start taking out what doesn't fit as you discover more symptoms.
Until the OP offers up more information (symptoms) on his process - this (at least to me) still remains a viable answer to the problem.
And FWIW - I agree with the coupling the hoses on the grapple together. I keep mine that way for that & to keep them clean and I have yet to have an issue either.
Me too.
Or is it me neither.
I always get those confused. :)
I usually say Me too neither just to be safe. :D
   / Front hydraulic couplings for grapple not releasing pressure #13
No apology needed here. Just discussing a problem and searching for a solution. :)
   / Front hydraulic couplings for grapple not releasing pressure #14
Well, as a newbie to stuff like this, I too have this question/problem. I recently hooked up some hydraulic lines for my grapple (everything is new to me, even the tractor) and when I disconnected the grapple I went to connect the two lines on the grapple side together and NO GO! Flat-face connectors, 1/2". I'm not exactly superman, but I'm no weakling either, but no way was I able to push the two connectors together. If I'm reading correctly, one should do this after things are warm: I was doing this cold- tractor and all. Learned something new today!:thumbsup:
   / Front hydraulic couplings for grapple not releasing pressure #15
Flatface couplers are worse because they are designed to not leak during connection. :(
Exactly why I got rid of the flat face couplers. I couldnt get them to re-hook no matter what. I would shut tractor off, turn key on (to energize diverter), and cycle the stick several times. Take them apart and couldn't reconnect even immediately after taking them apart. With my diverter being on the lift/lower circuit, I have a rubber band that lives around the joystick. Just slide it up over the trigger and detent into float.
Got tire of messing with it, and adding a front snow plow, I just swapped them to 1/4" 7241-B couplings to match what I run on snow plows.
As for the OP, its more cost, but they do make connect-under-pressure couplings that should solve the issues.
   / Front hydraulic couplings for grapple not releasing pressure #16
What you did was release the couplers with a "load". To prevent that you should shut the tractor off, then cycle the grapple controls to release any pressure, then disconnect.
Most common problem that is being discussed here is pressure that builds in the grapple system after it has been disconnected. Such as from heat expansion that occurs because of uncoupling during cool ambient temps then trying to recouple during warm ambient temps.
   / Front hydraulic couplings for grapple not releasing pressure #17
I only recall operating the valve lever, and dropping the lid (which had been parked open). Didn't seem like an issue disconnecting the hoses, didn't feel like there was much pressure.
   / Front hydraulic couplings for grapple not releasing pressure #18
If you are running your grapple with a simple mechanical hydraulic valve/lever, that should have done it. If you are running your grapple thru a diverter or electric over hydraulic 3rd function valve you would need power to the electrical switch before operating it to release pressure. All of this done in either case with the tractor shut down.
   / Front hydraulic couplings for grapple not releasing pressure #19
Richard, yeah, I'd read ahead of time on how to deal with this and I thought that I had done it properly, which is why I was a bit perplexed.
   / Front hydraulic couplings for grapple not releasing pressure #20
Yes tractor not running , but key on .
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
case 370 glass door never installed (A56436)
case 370 glass...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
2020 Deere 50G (A53317)
2020 Deere 50G...
