Front hitch without possibility?
/ Front hitch without possibility? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
/ Front hitch without possibility? #2
Can only be used with clevis-style pins on the implement. Needs another hose.
Bruce
Single acting is OK, but a "lift" that only pushes?
Fixed width. Why the ball ends? Someone must have pulled their ideas from pictures on the internet. ;-)
/ Front hitch without possibility? #4
Most front hitches are rigid and have hooks, but if it is used with a quick hitch, US or Euro style, it could be bolted or pinned.
The cylinder looks like a double action without a bottom hose installed.
Bruce
/ Front hitch without possibility? #5
Has all the looks of the beginning of another Rube Goldberg - to me. The attempt to combine multiple ideas into one final product.
I may be wrong, But I can imagine that most of us know the design features of "most" three point hitches ;-)
The image shows an exception.
How does a single action piston differ from a double acting? A plugged port here, a vent port there. Internal seals perhaps?
/ Front hitch without possibility? #7
If it is a double action missing a hose, no problem. If that is a double action cylinder used as a single, the hose is on the wrong end. If it is a single action cylinder that can only be used as shown, it won't work.
Bruce
/ Front hitch without possibility? #8
Maybe I'm a bit dense here, but is this really a front mount? Almost seems like something that goes on to a machine that isn't 3pt at the rear. I suppose that this is moot though...
Looks like there are two ports on that cylinder. If another hose were hooked up it might not look so puzzling?
/ Front hitch without possibility? #9
It has rigid arms (spacing) but should have centering chains/links because ball ends are going to be tough to get on implement pins unless there is some slack/movement.... But one could unbolt "centering" bar, install implement and then bolt back up bar....
Looks like once implement is installed it is not meant to be removed....
Dale
