Front end loaders dangerous
/ Front end loaders dangerous #1
ToJo
AL
Kubota L3400 FEL
If you buy a tractor with a FEL and you have never used one, the manual helps a little but it doesn't really tell you all you need to know, or maybe it does but you really don't learn much until you use the loader. I learned by using it that you can turn a tractor over very easily with it, much easier than I ever thought. I never turned it over but I came extremely close twice. Rule number one should be "never try to use a FEL sideways on an incline" Even a slight incline with the bucket loaded and up three or four feet will cause it to tip. If you start to tip, lower the bucket immediately, keep it low and try to back out of it. Rule number two should be " always travel with your bucket low to the ground whether it is loaded or empty". There are some other rules in the owners manual which are also important but these were the ones that I failed to pay attention to until I almost turned it over. Oh yes, one time I did it without the ROPS up and without a seat belt because I thought that I was going to be doing work which would make them unnecessary. Never try to use a FEL, even on level ground, without ROPS and lap belt. You can turn one over even on level ground if you drive over a hole or some soft ground with a loaded and lifted bucket. The best thing to do is always use ROPS and belt while on the tractor regardless of what you are doing. I don't think jumping off a rollover is possible in any circumstance, or at least, it would not be possible for me.
/ Front end loaders dangerous #2
Its also possible to drop material on your head, or to drop the bucket on somebody's head. Pretty easy also to put it through the side of your house if yhou don't pay attention.
/ Front end loaders dangerous #3
Too True…
To Alan I have to say amen…. To TOJO, There is no teacher like experience, also they have had loaders around much longer than there has been ROPS or seat belts. KennyV.
/ Front end loaders dangerous #4
I know this is an old thread but as a new BX2230 owner I would like to add that the next "rule" should definately be BALLAST. I hang 300 pounds on my 3pt when using the FEL.
I am a former heavy eq. operator...I worked in an above ground rock mine for years and ran various loaders ranging from a skid steer to a Cat 992G...we always had the back of the bucket "fenced" to prevent spillage when loading shot rock...I may do this to my BX bucket as well. I attached a rough drawing. Thoughts?
/ Front end loaders dangerous #5
</font><font color="blue" class="small">( I know this is an old thread but as a new BX2230 owner I would like to add that the next "rule" should definately be BALLAST. I hang 300 pounds on my 3pt when using the FEL. )</font>
I preach BALLAST and balance constantly. Seems like some folks think that they have enough but the case is you almost never have enough. Reading the loader manual typically will state that you need both a ballast box AND loaded rear wheels or wheel weights. Heavy tractors require the same care to have proper ballast as light ones do. Big ones require the same care as small ones. Proper ballast to balance the tractor probably does more to increase stability and useable capacity than most casual operators understand. I've simply stopped arguing with the knuckleheads who think they have a heavy tractor so they don't need ballast, they are simply dangers to themselves.
/ Front end loaders dangerous #6
)</font>
Agreed Bob...if some those guys had ever seen a Komatsu WA900 laying on her side they would be believers! /forums/images/graemlins/grin.gif
Slam
/ Front end loaders dangerous #7
Straight from Kubota:
</font><font color="blue" class="small">( Mr. Roy,
Below are the weights of each tractor with fluid filled R4 tires and a
front loader installed.
B7800HSD-F with LA403 Loader 3012 Lbs.
B7610HSD-F with LA352 Loader 2495 Lbs.
B2410HSD-F with LA352 Loader 2397 Lbs.
We also recommend that when you have your front end loader installed on
your tractor that you have an implement (Ballast Box, Boxscraper, tiller,
etc.) for counter weight. Even with your tires being fluid filled that
will not be enough weight to use as a counter weight.
Thank you for your interest in Kubota Tractors!
)</font>
This was the response I received from them when I was inquiring on some concrete numbers on weight. That tells me I need to go ahead and add the box scraper to the invoice when I make my tractor purchase. It was something I was going to get later.
Darrell
/ Front end loaders dangerous #8
The only thing that I would add is to be very careful not to "hang" one corner of the bucket on a rock or a tree root when digging. When most of these loaders raise from ground to full height in a few seconds, if you hang that bucket on a tree root, you'll be surprised how fast the back end comes off the ground and wants to tip the tractor over. That's what happened to me, even with ballast. It scared the daylights out of me. So when you lift the bucket, start slowly and give yourself a chance to react.
/ Front end loaders dangerous #9
Thats why I have ballast that won't let the rear end off the ground. People have told me $1800 was way to much to pay for a heavy duty box scraper but I say not only is it a better box scraper, but it makes a much better stabilizer for the loader. I think it was money well spent.
/ Front end loaders dangerous #10
The attachment is the plan I used to build my ballast "cube". The real thing works great. I found the plans here at TBN about 50 pages back in the DIY forum...I had no real use for a box blade and the weight boxes I looked at were not a good deal compared to the $35 I have invested in the cube.
Slam
/ Front end loaders dangerous #11
And it always pays to scout the area you're working in BEFORE you start moving material in the bucket so you don't get surprised by humps or potholes.
When my driveway was installed last May, the contractor excavated with his box blade and dumped piles of turf/earth all over my place. Had to spend a day smoothing these out so I wouldnt have a tipover while mowing or otherwise moving around my property.
Maybe it's overly cautious, but better safe than sorry. I've seen too many images in the Safety forum and elsewhere of tipped tractors to know that I don't want to get into that fix if I can help it.
/ Front end loaders dangerous #12
When I remove snow, I use both the FEL and 48" rear blade. Unfortunately, the small blade only weighs about 150 lbs which is far below the recommended weight for a counter-balance on my 2230. I don't have wheel weights or weighted tires. What can I do to add weight to my existing set-up to come closer to the recommendations?
/ Front end loaders dangerous #13
Jam - You covered a few of the options. The main ways to counter the loader forces are A) have a heavy attachment (backhoe, box blade, cement block etc.) on the 3ph (not an option when using your rear blade, unless you weld some big, heavy hunks of steel to the back side of it, which might not be a bad idea come to think of it), B) fill the tires, C) use wheel weights, D) install a backhoe subframe for its added mass (is this applicable to a BX2230?), and maybe see if you can hang something heavy off/between its rear "dogs" that won't interfere with the rear blade (big hunk o' steel?), or E) one of my personal favorites, a big, thick plate of steel (as thick as you want, 1" if you feel like it) under the tractor to act as both skidplate and a nice bunch of ballast way down low, just where it's needed. I happened to get lucky, and the backhoe subframe for my tractor allows for one solid piece to clear everything underneath.
I might add F) - think really hard about whether or not you REALLY NEED a quick-attach. I have it, but it does reduce your loader lift by virtue of its own weight, and it increases the leverage working on the rear of your tractor by moving the bucket several inches farther away from the loader arms.
Filled tires have the added benefit of not putting any additional load on the axles. I've never filled mine, but due to the attachments I have I never had to.
Oh, and I left out (G) - eat at McDonald's three times a day /forums/images/graemlins/laugh.gif
Let's be careful out there, keep it low and slow, and as has been mentioned, always be ready to drop that loader FAST.
BTW, here's a good thread: Tractor tipping - How easy?
/ Front end loaders dangerous #14
Jay,
<font color="blue"> I don't have wheel weights or weighted tires. </font>
If you want either one and for the least amount of money there are several threads on do it yourself ballast in tires and also there are pictures in the photo section that shows how the home made rear weights mount. Here are my weight brackets.
/ Front end loaders dangerous #15
jam2004--People are probably getting sick of this picture, but I had a welding shop add a post to my rear blade last year rear blade post with weights. You can't see it in the picture, but I also have wheel weights. Combined added weight is about 300 lbs. If you have a FEL, you NEED counterbalance weight of some sort, whatever combo meets your needs. You really shouldn't operate the FEL without it. Check the safety posts if you don't believe me... Good luck
/ Front end loaders dangerous #16
You are absolutely correct in preaching BALLAST. BALLAST, BALLAST.
I've had a B8200, B7100, B2150, and an L3010. all except the B8200 had FEL. I live in western PA with slopes everywhere. After trying the B7100 without filled tires and then with, the other tractors were either purchased with or had tires filled within first 48hrs of ownership.
The best way I can describe the difference between filled and not filled is the handling without filled tires is flat out vicious and VERY unforgiving. The tractor will tip with little or no warning and your chance of recovering it is nil. If you are just learning to operate one it is a VERY BAD idea.
The filled tires make the machine much more stable both front/rear and side/side. Additional rear ballast is good for front/rear balance but usually doesn't help side/side. The additional stability gives you additional time to respond to novice goofs without ending in disaster.
/ Front end loaders dangerous #17
</font><font color="blue" class="small">( think really hard about whether or not you REALLY NEED a quick-attach. I have it, ..., and it increases the leverage working on the rear of your tractor by moving the bucket several inches farther away from the loader arms. )</font>
Not really. The increased lever arm length is offset by reduced lifting capacity for a net zero effect. But, if you are loading the raised bucket by filling it using a conveyor belt, for example, it would act as you described it.
John
/ Front end loaders dangerous #18
Hmm, I'm going to have to think about this. Maybe I should have just stuck to saying that they reduce your net lifting capacity, but maybe there's still a leverage effect at work if you're lifting at anything less than your loader's full ability. To lift a given load that is under the maximum, the increased leverage still might work toward lifting the rear more than if you didn't have the QA.
In other words, at loads below the maximum lifting ability of the loader, perhaps the added weight of the QA is irrelevant, but the increased leverage remains a factor.
/ Front end loaders dangerous #19
Thanks everyone. I'm gonna get that taken care of ASAP. I like the welded work. But I may get wheel weights too.
jam
/ Front end loaders dangerous #20
Bucket curl however is dimished very little with a QA and that is where you can really heap the bucket. It is also why I find using my 1000 lb box scraper so useful as a counter weight as opposed to wheel weights. I use the box scraper considerably but it also adds tremendous ballast not only because of its weight but because of where it hangs that weight.
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
