front end loader won't lift
   / front end loader won't lift #1
Donibnole
Farmpro 2425
My front end loader on works when fluid is cold. The bucket won't even raise
when the tractor reaches operating temp. What is wrong, weak pump, leaking past a seal e.t.c
   / front end loader won't lift #2
It could be either of those or even a fauty PRV.
You really need to spend $10-$20 and get a hydraulic pressure guage. When the probem occurse, you can test the ports going out from the controls to the loader. If you are making at or near the rated pressure, the problem is beyong the valve. Like the hoses or cylinders. If you arent making the PSI there, it is either the pump or supply to the valve.
2014 TEXAS PRIDE GOOSENECK (A53843)
2014 TEXAS PRIDE...
Case 235 Tractor (A53117)
Case 235 Tractor...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
