front end loader won't lift
   / front end loader won't lift #1
Donibnole
Farmpro 2425
My front end loader on works when fluid is cold. The bucket won't even raise
when the tractor reaches operating temp. What is wrong, weak pump, leaking past a seal e.t.c
   / front end loader won't lift #2
It could be either of those or even a fauty PRV.
You really need to spend $10-$20 and get a hydraulic pressure guage. When the probem occurse, you can test the ports going out from the controls to the loader. If you are making at or near the rated pressure, the problem is beyong the valve. Like the hoses or cylinders. If you arent making the PSI there, it is either the pump or supply to the valve.
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2006 TerraGator 8104 (A53473)
2006 TerraGator...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
