Front End Loader Valve problem
/ Front End Loader Valve problem #21
Mad,
Yeah, good catch. I didn't read the original post that well.
jb
/ Front End Loader Valve problem #22
Mad,
jb
/ Front End Loader Valve problem #23
Here is a quick test to see if fluid is bypassing and going to tank. Dissconnect the return to tank hose where it connects to the transmission sump and set it into a clean bucket. Start your tractor. Fluid should not be coming out the hose. If it does then the relief valve is probably failing.
/ Front End Loader Valve problem #24
/ Front End Loader Valve problem #25
How old is this loader and valve? Who plumbed it in? Sounds to me like the may be a plumbing issue here. In, out, and power beyond sound out of whack.
/ Front End Loader Valve problem #26
/ Front End Loader Valve problem #27
</font><font color="blue" class="small">( Sounds to me like the may be a plumbing issue here. In, out, and power beyond sound out of whack. )</font>
If you read the original post of this thread you will see that the plumbing, as described, is correct. That's not to say the poster is reading the valve markings correctly but one has to assume he is since the failure started without disconnecting and reconnecting anything.
/ Front End Loader Valve problem #28
/ Front End Loader Valve problem #29
The relief valve on my Kubota stuck open slightly which made for no pressure in the 3ph. I took it apart and cleaned it, works great now. When this happened the FEL stopped working to. Does the FEL seem to pick up as much as it used to?
/ Front End Loader Valve problem #30
Both the 3 pt and FEL worked great 3 years ago when I bought it, trouble started after a friend pulled a stump with the FEL. FEL has worked fine since, but 3 pt gone bad.
John Churchill
John Churchill
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
Boom Sprayer (A64127)
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
