Front End Loader Problem
   / Front End Loader Problem #1
Al Crandall
New Holland T4.75
Have a New Holland t4.75 with a 655 tl front end loader, handle that started getting hard to push side to side to tilt bucket, the next day lever was hard to push to raise and lower lift, checked Hydro fluid and it was good, thanks for any help.
   / Front End Loader Problem #2
Are there cables from the joystick to loader valve? If so, I would start with the cables.
Thanks, I'll check it out.
   / Front End Loader Problem #4
If your joystick has cables and further if it has a lock on the joystick to prevent inadvertent loader movement when on the road, start by locking the joystick.
The cable ends will connect to the loader valve spools with pins. Remove the pins so the spools can be centered without cable influence.
Now adjust the outer cable at the loader valve until the holes in the cable ends line up with the holes in the valve spools. Then reinstall the pins.
When the pins connecting the joystick cable are removed, unlock the joystick and check for easy smooth joystick movement.
Re-lock the joystick if cable movement is smooth and center as noted above.
Dave M7040
Thanks guys, I love this forum.
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
