Front End Loader Hydraulics,
/ Front End Loader Hydraulics, #1
LP1
Middle Tennessee
New Holland TC33D
So, I watch these videos on YouTube and everyone always shows the FEL lifting the front of the tractor up. Well, mine won't do that. It just whines at full throttle. The guy I bought it from sold it because the FEL wouldn't lift a bail of hay. Everyone I talked to said a New Holland TC33D wasn't going to lift a big roll of hay, but I've seen dozens of them lift the front and off the ground. OK, so what should I check?
The hoses look good and to be honest I haven't had time to check the fluid level and I don't even know where the check plug (or whatever) is. Any help without pointing and laughing at me would be greatly appreciated....... :laughing:
Sorry, I forgot to mention it's a 7308 front end loader.
/ Front End Loader Hydraulics, #3
Tee a gage into the line, set loader relief for about 2500 Psi
Check the Main pump pressure, shim relief as required, then set loader relief 100-150 psig less.
/ Front End Loader Hydraulics, #4
mikes words are "the true story". ;-)
Thanks for the advice. I read it several times.
I feel like I need someone to translate it for me. :laughing:
Could someone "dumb it down" a bit for me?
Where would I put the gauge and what does "shim relief" mean?
/ Front End Loader Hydraulics, #6
Do you have the bucket tipped forward when you try and lift the front of the tractor ?
/ Front End Loader Hydraulics, #8
....Where would I put the gauge and what does "shim relief" mean?
Read this thread, mainly the last one... (beware we had "double posting-itous" back then).
http://www.tractorbynet.com/forums/new-holland-owning-operating/81000-tc30-hydraulic-pressure-2.html
So I don't know your tractor but tractor's operate at a certain PSI - I think yours might be 2200 MAX). Shims will compress the pressure release valve, making it tighter, thus raising the operating pressure...
/ Front End Loader Hydraulics, #9
I've never found a machine that wouldn't still do it.
/ Front End Loader Hydraulics, #10
Any pressure line on the hydraulics will work. The easiest is probably the quick attach couplings. Unscrew a couple and figure out the threads. It's probably 1/2 NPT. Now go buy a T, a double male connector and a can of thread sealant. Put the T between the coupling and the piece you just unscrewed it from. Put a pressure gauge on the remaining port. Make sure everything you use is 3000 psi pressure rated.
/ Front End Loader Hydraulics, #11
Try putting taking the tractor out of gear to get the front up. If you have the 1 3/4" cyls you might not be able to with it trying to pull the tractor fwd.
/ Front End Loader Hydraulics, #12
/ Front End Loader Hydraulics, #13
LP1, you stated in your first post you had not checked fluid level. That should have been the first thing checked. When you check, make sure there are no shinny metal filings in the fluid. How many hours on the tractor?
Sorry it took me a while to reply. There are 1500 hours on the tractor. After re-reading some of the replies and trying to learn terminology I watched a few videos again. It appears I was "doing it wrong". I was turning the bucket down and then pushing into the ground. I tried last night by lowering the loader and THEN "curling" (a term I was unfamiliar with) the bucket down. It raised the front end up no problem. I will be checking and replacing the fluid this weekend.
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
2024 Ranger XP 1000 North Star (A62679)
2024 Ranger XP...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
