front End Fluid
   / front End Fluid #1
mike65cobra
Kioti CK HST
Hi can someone tell me if it is okay to use the trnasmision/hydr fluid in the front end also? Thank-You Mike
   / front End Fluid #2
On my CK30 you could choose hytrans or gear oil. Since this is a differential with gears, I choose gear oil.
OEM fill was hytrans.
   / front End Fluid
Sorry to tell you i have a CK35 HST.
   / front End Fluid #4
If your ck35 has 4 wheel drive, I'd think gear oil would be what is used.
   / front End Fluid
Yes it is 4 wheel drive. Mike
   / front End Fluid #6
My dealer had me switch from gear oil to Hyd/Trans fluid. If it's good enough for the gears in the rear end I don't know why it's not "OK" for the gears in the front end.
   / front End Fluid
Thanks for all your help. Mike
   / front End Fluid #8
We use hydraulic oil.
BTI
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
378803 (A51573)
378803 (A51573)
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
