Front differential oil replacement.
/ Front differential oil replacement. #1
TX2140
Iseki TX2140
When in 4x4 there is a sqeel that seems to be coming from around the front diff. Loudest when in high range 3rd gear. When I removed the drain front differential drain plug no oil came out. The hole was dry and dusty.
I cannot find where to pour the oil into. Can anyone help me please ?
Any pictures would be greatly appreciated.
/ Front differential oil replacement. #2
what's the make and model of your tractor?
Iseki TX 2140
/ Front differential oil replacement. #4
I think this may help you. It is for another model but may be similar to your tractor.
  • Service-IsekiTM15.pdf
/ Front differential oil replacement. #5
You have the same I have, except mine is a Bolens. Attaching a manual. Page 12 of the Bolens manual shows the fill and drain plugs. That manual is for the 2 cylinder, but the rest of the tractor is mostly the same.
Another manual for the TX2140 is available if you type this into Google
TX2140 Parts Catalogue 2&4-Wheel drive type Iseki PDF
I am not sure if this link works, but I get a download from this website
  • Bolens G154 Iseki-H1704-Owners-Manual.pdf
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65056)
2020 HAULOTTE...
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
PORTA POTTY (A67714)
Generator (A64553)
Generator (A64553)
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A68842)
PALLET OF MEC 8000...
