Front Differential Fluid - CT235 - (50 hr service)
   / Front Differential Fluid - CT235 - (50 hr service) #1
beltfed
Northern VA
Bobcat CT235
I'm about to do the 50 hour service this week and have a question.
I believe I have everything ready except while re-reading the manual, I see the front differential fluid amount say 4.75qt's (each.) What does the each mean? I picked up 5 quarts of fluid and now wonder if I needed to double that amount.
Any other things I should be aware of while doing the 50 hour service?
   / Front Differential Fluid - CT235 - (50 hr service) #2
I think the term "each" means if each/both spindles are drained. In back of the service manual wher is specifies type of fluids to use it states Front Axle 90W gear lube - 4.75 qts.
Make sure you check, retorque your wheel lug nuts and the loader mounting bolts.
   / Front Differential Fluid - CT235 - (50 hr service) #3
Where it says '4.75 Quarts, 4.5L Each' it is referring to front Axles and logic says we have One (1) front axle so I think you are good. I cannot see getting more than 4.75 quarts in that entire space either.
Alright, thanks. I'll try to remember to take photos if anyone is interested.
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
2022 Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A53485)
2022 Kuhn Axis...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
202477 (A54757)
202477 (A54757)
183 (A52705)
183 (A52705)
