Front Cowl, Rubber Grommet
   / Front Cowl, Rubber Grommet #1
KEROSENEDRVR
N. California
DK35
I just noticed the rubber grommet which holds the front cowl into the chassis is missing. To clarify, the cowl has two pins which sit inside a grommet which is mounted inside a hole on the chassis.
Is there a source for the grommets other than Kioti??? I'm hopeful the hardware store or lowes would carry a similar product. Any suggestions?
   / Front Cowl, Rubber Grommet #2
It might be hard to match but you may be able to at a hardware store... We usually keep stock of these as they come loose from time to time... When we replace one or sell them we suggest using some silicone to hold it in better.
   / Front Cowl, Rubber Grommet #3
Anyone who repairs auto bodies should be able to help you. When I worked in a body shop we always had a bunch to put in firewall penetrations for wires and hoses.
   / Front Cowl, Rubber Grommet #4
They are avail from Kioti and are extremely well priced.
KO
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
