Front Cowl, Rubber Grommet
   / Front Cowl, Rubber Grommet #1
KEROSENEDRVR
Bronze Member
N. California
DK35
I just noticed the rubber grommet which holds the front cowl into the chassis is missing. To clarify, the cowl has two pins which sit inside a grommet which is mounted inside a hole on the chassis.
Is there a source for the grommets other than Kioti??? I'm hopeful the hardware store or lowes would carry a similar product. Any suggestions?
   / Front Cowl, Rubber Grommet #2
It might be hard to match but you may be able to at a hardware store... We usually keep stock of these as they come loose from time to time... When we replace one or sell them we suggest using some silicone to hold it in better.
   / Front Cowl, Rubber Grommet #3
Anyone who repairs auto bodies should be able to help you. When I worked in a body shop we always had a bunch to put in firewall penetrations for wires and hoses.
   / Front Cowl, Rubber Grommet #4
They are avail from Kioti and are extremely well priced.
KO
Scag Mower (A50324)
Scag Mower (A50324)
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
