Front coupling ball bearings
   / Front coupling ball bearings #1
Clark-Kentski
branson
I had to pull the steering cylinder off my old 3510 today,what a chore !had to remove the 4. 1 1/16 bolts that hold the front axle in and raise the frame to get the cylinder out.My issue is is 6 ball bearings came out of the coupling.How to I go about putting it back together ? I’m thinking Vaseline might hold them while I maneuver the front unit into the shaft ?. Anytips ? Thanks !!
   / Front coupling ball bearings #2
Welcome to the forum.
Either vaseline or just grease will work just fine. Lubricate all the splines on the shaft while you're at it.
Thanks , Fellas ! Great video but mines a 2006 and the cylinder has steel plates welded at a 90degree angle.The long bolt trick would work but would have to be very long.I’m hoping my drive shaft will slide back like you say because trying to deal with the front axle and those bearings would be hard to get together all at once.Hopefully I can install the cylinder and bolt the axle back up tight and the deal with the shaft and bearings last.
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
