Front bumper for a 5103
   / Front bumper for a 5103 #1
usmc5595
Bronze Member
Does any one have one? Has any one built one?
Looking for pictures and info. I am wanting to build one for my tractor with a "D-ring" for pulling stuff.
Does anyone know what the threats are on the front (4 holes)
   / Front bumper for a 5103 #2
Those holes are probably for a front weight bracket, BTW.
I suggest you'd be better off using the draw bar below the rear PTO. It's there for towing and located at a very strong part of the tractor and you'd get better traction pulling from the draw bar.
If you have ag (R-1's) or industrial (R-4s) tires, the treads would be working against you.
Clevis type "D" rings are pretty easy to obtain (for the draw bar) too.
Any particular reason why you want to pull from the front?
   / Front bumper for a 5103 #3
Why stop with only a D-ring/bumper? Build your bumper with a trailer hitch receiver tube. That way you insert/remove any adapter, easily, you care to use. (Ball hitch, d-ring, pintale)
I have needed to pull it out like that when it was stuck, and I cut a lot of saplings/trees so a front bumper would be nice to bend over the brush and help it go under the tractor. The reciver hitch is a good idea
   / Front bumper for a 5103 #5
Go to GR Manufacturing web site as they build forestry/ROW equipment for Deere tractors.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
CUSHMAN HAULER PRO GAS GOLF CART (A54756)
CUSHMAN HAULER PRO...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2018 FORD EXPEDITION (A51406)
2018 FORD...
