front bucket want work
/ front bucket want work #1
hillbillyorange
kentucky
kioti lk30 tlb
I HAVE A 2008 KIOTI LK30TLB WHEN I TAKE THE BACKHOE OFF AND TURN THE DEVERTER BLOCK SO THE PUMP DONT DEADHEAD THE BUCKET WANT WORK HOW DO I GET THE FRONT BUCKET AND 3 POINT HITCH TO WORK TOGETHER THANX
/ front bucket want work #3
Geeze, you didn't give us a chance to answer, we do go outside once in a while to, among other things, run our tractors.
On the LK which I'm fairly certain is the same set up as mine, you disconnect the hoe and the hoe's hoses from the rear of the machine you then unhook the hose on the diverter block that returns from the hoe and unhook the hose connection that goes to the hoe and plug into the diverter block to complete the cuircut, it is a single pump and cuircut on the LK.
Your manuals should show you this? Dealer should've walked you through this, a little confusing the first time through.
You do not change the valve on the diverter block.
Joel
i knew more then the dealer shove me out the door took him 2 months toget me manuals thanx alot for the information
/ front bucket want work #5
The LK30 Hydraulic Block is slightly different than the LK3054 or 3054XS. The diverter valve needs to be rotated pin down for Front Loader or Backhoe operation. If you rotate the diverter back up, you turn off flow to the loader.
If you remove the backhoe (KB2376), plug the power beyond from the loader to the lower left quick connect on the tractor hydraulic block instead of the backhoe power in hose. This will give you Front Loader and 3-point control.
With the Power Beyond from the loader plugged into the backhoe, you have Front Loader and Backhoe, but no power to the 3-point.
Hope this helps.
is there any way u could send me a pic of how this is hooked up on tne block i think they left some quick couplings off my machine it would be greatly appreciated thanx
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
2018 John Deere R4030 Sprayer (A63111)
2018 John Deere...
