front bucket want work
   / front bucket want work #1
hillbillyorange
kentucky
kioti lk30 tlb
I HAVE A 2008 KIOTI LK30TLB WHEN I TAKE THE BACKHOE OFF AND TURN THE DEVERTER BLOCK SO THE PUMP DONT DEADHEAD THE BUCKET WANT WORK HOW DO I GET THE FRONT BUCKET AND 3 POINT HITCH TO WORK TOGETHER THANX
GUESS NO ONE KNOWS THANX ANYWAY
   / front bucket want work #3
Geeze, you didn't give us a chance to answer, we do go outside once in a while to, among other things, run our tractors.
On the LK which I'm fairly certain is the same set up as mine, you disconnect the hoe and the hoe's hoses from the rear of the machine you then unhook the hose on the diverter block that returns from the hoe and unhook the hose connection that goes to the hoe and plug into the diverter block to complete the cuircut, it is a single pump and cuircut on the LK.
Your manuals should show you this? Dealer should've walked you through this, a little confusing the first time through.
You do not change the valve on the diverter block.
Joel
i knew more then the dealer shove me out the door took him 2 months toget me manuals thanx alot for the information
   / front bucket want work #5
The LK30 Hydraulic Block is slightly different than the LK3054 or 3054XS. The diverter valve needs to be rotated pin down for Front Loader or Backhoe operation. If you rotate the diverter back up, you turn off flow to the loader.
If you remove the backhoe (KB2376), plug the power beyond from the loader to the lower left quick connect on the tractor hydraulic block instead of the backhoe power in hose. This will give you Front Loader and 3-point control.
With the Power Beyond from the loader plugged into the backhoe, you have Front Loader and Backhoe, but no power to the 3-point.
Hope this helps.
is there any way u could send me a pic of how this is hooked up on tne block i think they left some quick couplings off my machine it would be greatly appreciated thanx
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
Wooden Sleigh (A50774)
International Tandem Dumo TRUCK (RUNS)(TITLE)(LOCAL TOWNSHIP) (A50774)
International...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
