Front Blade
   / Front Blade #1
Bob_Bullock
I have been looking at different options for a front plow to go on my 7308 loader. Some of the other posters have suggested getting the quick attach for my setup. Below is a price I got from a local dealer. Seems like a lot of money. Please let me know if this is normal or not.
Thanks
Bob
HAVE TO SWITCH YOUR LOADER OVER TO A QUICK ATTACH THE PLATE FOR YOUR
> BUCKET AP. $300.00
> THE ADP. FOR THE LOADER AP. $750.00 TO CUT BACK PLATE OFF OLD
> BUCKET AND WELD ON NEW PLATE AP.
> 5HRS AT $70.00 PER HR
   / Front Blade #2
I'm not quite sure I understand all your abbreviations, but the numbers seem big.
I have a tractor due soon with the QA bucket and plate. I think the price difference was in neighborhood of $200, with the dealer keeping the pin-on bucket.
I think I can weld up a heavy steel plate to fit the QA loader easily enough -- call it my frame. I have taken my old 3 point blade apart. The blade proper pivots in a heavy bushing arrangement, and is locked in place through the simple expedient of holes in a flat steel plate lining up with a hole in the frame. If you have an old back blade lying around, look at how it works. All you need to do is have someone fashion a way to attach the pivot assembly to a plate that fits your QA points on the FEL. It shouldn't be a big deal to someone with metalworking experience.
You're right, it does seem like a lot of money. Get a price on the QA adapter that fits your FEL. Go to a welding shop and ask about the rest. Take some pictures or a drawing and see what they can do for you.
   / Front Blade
Rich,
Just got pricing from my local guy. $700 for the quick attach that goes on the 7308 loader. $175 for the QA adapter that goes on the bucket. They have to cut the mounts off and then weld the QA adapter to the bucket. Still seems like 5 hours at $70 per hour is hefty. I am going to check some local fabricator guys that might be able to do the work.
Thanks
Bob
   / Front Blade #4
I ordered mine for a tractor that was sitting on the lot. The QA system has a different bucket -- it holds a bit more material, is a slightly different shape. Guess I was wrong on the cost, but I can check. That seems like a lot for the QA plate that pins on the arms.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
