Financing Front axle
/ Front axle #1
Terry Baumgardner
I have an Ag King 2840 (Jinma) I am not much of a mechanic. There are not any dealers of these units within 200 miles of where I live. Yesterday evening while working my driveway out the left front wheel fell off while moving. The hub is still on the wheel. The axle looks like a saw cut it in half. I need to find a parts diagram so that I can purchase new parts. I dont have a clue to what is needed with out it. Is their one I can down load? I dont know how to go about getting the rest of the shaft apart.
Thanks:ashamed:
/ Front axle #2
As you state, it's a re-badged Jinma. Possibly the JM284. There are 4 manuals for the 200 series
1. tractor operations & maintenance
2. tractor parts
3. engine operations & maintenance
4. engine parts
note: you must specify which engine when ordering
Any Jinma dealer should be able to provide you with all four, and I definitely recommend buying the whole set
//greg//
/ Front axle
2. tractor parts
4. engine parts
//greg//
Thank you for your help.
/ Front axle #5
been there done that. the axle has sheered off in the drive housing. not hard to repair. normally happens when the tractor is in 4x4 and using FEL to load / dig with. the front tires get too much traction and the power twists the axle stub shaft. Cost me some time was worst price was not bad & bought every thing form Tommy @ affordable. I didnt think the bearings felt bad when I ordered the parts but after getting the new parts and starting the assembly the bearing felt bad. so I ordered the bearings as well. all works well after wards and should have only took an hr to to do the job but I played around with it and needed extra time to get the bearings. Which was OK except that during the shipping the gasket was damaged tommy sent a new one with the bearings.
Job is easy to do just takes some work and all...
good people to work with down there @ Tommys too.
mark
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
