Financing Front axle
/ Front axle #1
Terry Baumgardner
I have an Ag King 2840 (Jinma) I am not much of a mechanic. There are not any dealers of these units within 200 miles of where I live. Yesterday evening while working my driveway out the left front wheel fell off while moving. The hub is still on the wheel. The axle looks like a saw cut it in half. I need to find a parts diagram so that I can purchase new parts. I dont have a clue to what is needed with out it. Is their one I can down load? I dont know how to go about getting the rest of the shaft apart.
Thanks:ashamed:
/ Front axle #2
As you state, it's a re-badged Jinma. Possibly the JM284. There are 4 manuals for the 200 series
1. tractor operations & maintenance
2. tractor parts
3. engine operations & maintenance
4. engine parts
note: you must specify which engine when ordering
Any Jinma dealer should be able to provide you with all four, and I definitely recommend buying the whole set
//greg//
/ Front axle
2. tractor parts
4. engine parts
//greg//
Thank you for your help.
/ Front axle #5
been there done that. the axle has sheered off in the drive housing. not hard to repair. normally happens when the tractor is in 4x4 and using FEL to load / dig with. the front tires get too much traction and the power twists the axle stub shaft. Cost me some time was worst price was not bad & bought every thing form Tommy @ affordable. I didnt think the bearings felt bad when I ordered the parts but after getting the new parts and starting the assembly the bearing felt bad. so I ordered the bearings as well. all works well after wards and should have only took an hr to to do the job but I played around with it and needed extra time to get the bearings. Which was OK except that during the shipping the gasket was damaged tommy sent a new one with the bearings.
Job is easy to do just takes some work and all...
good people to work with down there @ Tommys too.
mark
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A65055)
UNUSED FUTURE MINI...
JOHN DEERE 7800 TRACTOR (A65054)
JOHN DEERE 7800...
More Info coming soon (A64557)
More Info coming...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A64553)
2006 Generac...
(2) PREDATOR GAS AUGERS & (1) BRIGGS & STRATTON (A65055)
(2) PREDATOR GAS...
