Front Axle Pivot Leak
   / Front Axle Pivot Leak #1
AceDeuce
Northern Virginia
Kubota BX1500 w/ R1's and LA181 FEL
The other day I noticed a leak that appears to be coming from the pivot pin on the front axle of my BX. It's either age or FEL use, but regardless it needs to get fixed. Questions: 1.) I only want to do this once, so I was planning on replacing not only the o-rings but also the bushings. Should I go ahead and replace the pin too? 2.) Do I need any special tools for this job? A drift for the bushings? Is a special tool required for the o-ring back up? Any tips from someone who has done this before would be great! Thanks.
   / Front Axle Pivot Leak #2
Ain't it just a swivel point that just takes grease? My L2800 is.
I couldn't believe it either. Struck me as a weak design. But yes, the pivot pin actually penetrates the fluid reservoir in the axle and therefore must be sealed. Kubota uses an o-ring on either side that seals against the pivot pin.
  • BX front axle.pdf
   / Front Axle Pivot Leak #4
AceDeuce,
Did you get a chance to mess around with your front axle pivot leak yet? I think I have the same problem and was wondering what you found out.
Wes
   / Front Axle Pivot Leak #5
You have to adjust the torque of it every so many hours per manual.
   / Front Axle Pivot Leak #6
Yeah, I've done that twice now. I only have about 500 hours on the tractor.
If I need to do any repair on it I will wait until spring. I am thinking it could be leaking a little because of the snow plowing and rough terrain. When plowing snow I tend to go fast to make the snow roll off the plow nicely. The tractor tends to bounce a lot.
I assume the oil is SUDT (which is used in the front axle) and not engine oil that is leaking from this spot. I do check both dipsticks and the oil is ok in both.
Wes
   / Front Axle Pivot Leak #7
Have you fixed yours yet AceDeuce? I just finished fixing the same problem you have on my 02 bx2200 1050 hrs. The rear bushing was paper thin and leaking bad, not to mention a loose axle that could not be tightend anymore.
If you have some basic mechanical skills, you should be fine. I also replaced the spindle pivot seals since they were full of dirt and leaking. That made the axle lighter to put up on a vice and get the bushings out.
The bushings cannot be driven out. I tried. They bottom out flush to the casting. I used a straight hacksaw to work an edge and a punch to bend them in and pulled out. You probaby could work them out without sawing by punching where the gap is, just be careful near the o-ring sealing area. I had the spindle off and cleaned the shavings from inside. I put the new bushings in the freezer (probably not necessary), then tapped them in with a hammer & socket.
I also replaced the bolt, which was badly worn, the o-rings, and nylon washers which were almost non existent.
I also took apart the spindles which were leaking. They were not as hard to do as I thought. Seems the problem was dirt getting in the spindle seals and wrecking them. There was a lot of small metal shavings in the oil and some wear on the gears. Last changed about 200 hours ago to 80w90. The bearings seem tight, so I put it back together. I assume the moderate gear checking is due to hours and hard use with a loader.
I turned the compost pile, and moved some dirt with it today and no leaks. Much tighter steering also. Overall, not too bad to work on, although the design of the center pivot would be MUCH better if it were separate from the axle case and grease lubed.
   / Front Axle Pivot Leak #8
ok - i know this is an old thread. i just got a new to me bx22 with this pivot leak issue. I didnt realize it until a bit after i got it home
my machine has a loader and backhoe - when i try to remove the pivot pin it bumps into one of the metal hydraulic lines that is for the loader
Q1: do i need to move this line or is there something im missing
Q2: if there is a method to get the pin out without taking the hrdraulic line off - how much room do i have to lower the front axle? doesnt seem like much play in the power steering lines
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
378801 (A51572)
378801 (A51572)
Utility Cart Bed (A50325)
Utility Cart Bed...
FAKE (A52472)
FAKE (A52472)
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
