front axle pin
/ front axle pin #1
devildogduane
monroe,washington
mitsubishi
Thank you all for your help! I am new to tractors. I did have another ujoint farther back on the driveshaft that was just packed full with dirt making it hard to move the shaft. So, I have put the drive shaft together so far twice. Once it fell off towards the front and then another at the slip u joint. I get a couple loads and then it will pop off. I have noticed a pin up front holding my axle to the frame that has worked its way out. I am thinking this is causing the front to twist a bit causing the ujoints to pull apart. My problem is what is used to hold the large pin in. It has a plate on the front with a zerk fitting to hold it from going forward but nothing to stop it from working out to the rear. Any ideas would be awesome.
Also, if you know of the nearest new tractor repair manual that is closest to this tractor please let me know.
Thanks, Duane
/ front axle pin #2
what model ford is this
/ front axle pin #3
G'day I would be taking that front plate off and having a look there could be a circlip popped off or it could be a stepped pin in which case the pin could be broken:eek:. In any case I would hold off using the machine until it is fixed.
Jon
2017 KOMATSU D61PXI-24 CRAWLER DOZER (A64279)
2017 KOMATSU...
5'x8' PT Single Axle Welding Utility Trailer (A64119)
5'x8' PT Single...
2020 KOMATSU D51PX-24 CRAWLER DOZER (A64279)
2020 KOMATSU...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
COMBINATION ELETRICAL & COOLING SYSTEM (A64281)
COMBINATION...
