Front axle lubricant S373D
   / Front axle lubricant S373D #1
Irishman73
Linton, IN
Satoh/Mitsubishi S373D
Anyone know what is the best for the front axle? I have a seal leaking and I need to keep it topped off.
   / Front axle lubricant S373D #2
The manual for my MT372, which is very similar to your tractor says to use gear oil GL-4 or better. 75w to 90w depending on ambient temperature. A GL-4 80w90 should probably do it just fine.
   / Front axle lubricant S373D #3
View attachment 389043View attachment 389044
I am attaching a page with an oil chart from the 373 operator's manual, which I assume is pretty much the same chart as Skylarkguy was quoting.
View attachment 373 oil .pdf
Note that in addition to the gear oil already mentioned, one can also use certain hydraulic oils in the front axle. Since a reportedly reliable source says to disregard the manual and to NOT use gear oil in the trans.*, and since it is apparently OK to use hydraulic oil in both the trans & the axle, I have elected to use the hydraulic oil (in this case, a "303" oil) in both to avoid having all these different oils in different places. Maybe that's a good idea, and maybe not, but that's what I did.
Valley Power
Q: My manual says to use gear oil in the transmission. Is this right?
A: No. The manuals were incorrect. Most Mitsubishi tractors use a single system in which the transmission uses the same fluid as the hydraulics. Use Universal Tractor Fluid, AW46 Tractor Hydraulic Oil, JD Type 303 Special Purpose oil or the equivalent. An exception to this is the Satoh S650G, S670 and ST2500. These tractors have a split system with a separate hydraulic reservoir
Since it is leaking, would I not be better off using a thicker oil?
   / Front axle lubricant S373D #5
I cannot answer that question.
If it were me, I would either use what I normally use, or i would look into replacing the seal. Whether I would replace the seal or not would depend upon who bad it leaks, and how often I need to use the tractor.
I personally would not use anything "thicker" than the book recommended in the axle.
I plan on using the recommended gear lube, I use the tractor for mowing weekly. With that I cannot tear into it to replace the seal yet.
I am a little leery of using the hydraulic fluid since it is thinner. I will use the gear lube, at least until I can buy and install the seals.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Utility Trailer (A52377)
Utility Trailer...
