Front axle gear oil
   / Front axle gear oil #1
Alan57
South West Missouri
LS MT345E
Is Lucas 80w-90 Heavy Duty Gear oil a good choice for front axle?
   / Front axle gear oil #4
I used the 85w140 in mine. Usually this weight is full synthetic. Any brand will do.... it's not a " high speed axle". The synthetic 140 wt has very high sheer rating
   / Front axle gear oil #5
My 2007 Branson 6530 came with THD fluid specified for the front axle. After some embarrassing actions, I tore up the front bearings. I decided to use 85W-140 (living in Texas) for the fluid after I repaired it and that was the end of that.
Fast forward: I buy a 2016 Branson 2400.......I later traded for my current LS MT225s. The fill cap/dipstick on the front axle had stamped 80W-90 as was specified in the OM, not THD fluid.......... So here is a case where somebody realized that THD isn't necessarily what you use in your front axle when you work your machine really hard. So, what did I do with my 225 as soon as the dealer delivered it? You guessed it...... in with the gear oil brand new tractor. Haven't been sorry with over a year's usage now.
Yeah I know the yackety yack exceptions where you went to the moon with your THD but this is my story....and I'm not planning any trips to the moon. Grin.
Additionally, I had a Tough Torque hydro riding mower not survive an impact with a rigid object. Tore into it, found the bad part and ordered from TT. When I got the parts I had the parts I ordered, a gimmie cap, and a note that said basically, up the viscosity of your fluid!
   / Front axle gear oil #6
What's the spec? My LS specs GL4 in the front axle. GL5 or it being synthetic is not an automatic substitute.
Good point, the specs call for GL4 in front axle. The Lucas I used is rated at GL5 and is a non synthetic. I wonder if using the Lucas will do any harm? When I got the tractor back from a dealer after some warranty work and the front axle was 2 qts low so I used the Lucas to top it off.
   / Front axle gear oil #8
Any idea why it was 2 quarts low ?
I park it inside on new concrete floor and there are no signs of leaking so I’m assuming the dealer didn’t fill it completely after repairing a front axle leak.
   / Front axle gear oil #10
Hopefully you didn’t somehow over fill it
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
