front axle fluid level
/ front axle fluid level #1
kennerk
LS M235E
Hello , going over my new to me LS M235E tractor and checking all levels.
I took the blue cap off of the right front axle to check fluid level, it has no dipstick and when looking down the hole I can see just a little oil way down at the bottom of axle housing, not sure if it is low or needs gear oil, how to tell proper oil level, I thought there would be a dipstick connected to the blue cap.
Thanks
kenner
/ front axle fluid level #2
Check the other side. They usually put the vent on one side and the dip stick on the other side.
/ front axle fluid level #3
Yes, the dipstick is on the left (Drivers) side under the metal nut.
Check it every 2 hours for the first 20 hours. Many of us with MT230/235/240 tractors have had to add up to 2 quarts total over the first 20 hours and then it was stable.
I last checked mine around 275 hours and it was still near the upper mark.
All right, thanks for the help, I will check it out tomorrow.
Thanks
kenner
/ front axle fluid level #5
Some front axles have a check port on the side and a fill port on the top, like a regular gear box. Pull the check port, if fluid is at the bottom of the threads when parked on a level surface, then you're good.
2013 MAC LTT 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2013 MAC LTT 150...
Wolverine Skid Steer Land Leveler, 78" (A62679)
Wolverine Skid...
John Deere 772-A Grader (A62679)
John Deere 772-A...
John Deere 4955 (A64126)
John Deere 4955...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2017 Paladin Mini Excavator Auger w/Bits (A64126)
2017 Paladin Mini...
