front axle fluid level
   / front axle fluid level #1
kennerk
LS M235E
Hello , going over my new to me LS M235E tractor and checking all levels.
I took the blue cap off of the right front axle to check fluid level, it has no dipstick and when looking down the hole I can see just a little oil way down at the bottom of axle housing, not sure if it is low or needs gear oil, how to tell proper oil level, I thought there would be a dipstick connected to the blue cap.
kenner
   / front axle fluid level #2
Check the other side. They usually put the vent on one side and the dip stick on the other side.
   / front axle fluid level #3
Yes, the dipstick is on the left (Drivers) side under the metal nut.
Check it every 2 hours for the first 20 hours. Many of us with MT230/235/240 tractors have had to add up to 2 quarts total over the first 20 hours and then it was stable.
I last checked mine around 275 hours and it was still near the upper mark.
All right, thanks for the help, I will check it out tomorrow.
kenner
   / front axle fluid level #5
Some front axles have a check port on the side and a fill port on the top, like a regular gear box. Pull the check port, if fluid is at the bottom of the threads when parked on a level surface, then you're good.
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
