front axle break foton ft254a
/ front axle break foton ft254a #1
rb33
scottsdale az
06 foton 254A
1st time tractorowner,bought a used foton ft254a 2006,this site has been very usefull,yesterday i snapped a front right axle, dissassembled & now the parts hunt begins any help would be appreciated, thanks rb33
/ front axle break foton ft254a #3
then try Affordable tractor, Tommy can find just about anything.
/ front axle break foton ft254a #5
Greetings, Can I ask how you snapped the axle? I have the a 2005 Foton 254a. Thanks Richard
working in wash area,fel loaded to max on slope right wheel higher than left
went to back up & snap not sure if in 4wd at time.
donny at discount is pulling one apart as I type to see if it will match.
I will call tommy next if necessary
richard
due to holidays parts were shipped out monday,they should arrive thurs.
parts ordered from "donnie" at "pecan parts .com" they had eveything & a
full on line parts & operation catalog. I will post how things go this weekend.
rb33
alright,parts arrived as scheduled now to install
I did not want to remove the housing assemble so here is how I went at it.
1st had to pull out broken axle,so i drilled & tapped a 1/4''
hole in shaft & used a slide hammer to pull out both shaft& bearing then removed the shaft from bearing in press. now to start.
1.place shaft bolt side down on 4x4 notched out for bolt
2.slide outer cover over shaft with bearing & seals
installed
3.Installed split ring lightly greased over groove in shaft
4.slide gear on carefull to seat split ring
5.place assemble on press & install inner bearing
6.installed 4 studs in to housing on front hub
7.slide shaft assemble on studs & push to seat
8.install bolts, leave studs in & tighten evenly and rotate to mesh gears
hope this is helpfull to others
randy
/ front axle break foton ft254a #11
Randy, Good for you! It is up and running. Yes, your discription would someone doing that job! Hope never to need it. Richard
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
CASE 105C (A62177)
CASE 105C (A62177)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
LOOK! (A63111)
LOOK! (A63111)
