Oil & Fuel Front axel oil/fluid
   / Front axel oil/fluid #1
TheMan419
Indiana
New Holland Boomer 24
I own a new holland boomer 24. It has about 30 hours on it. Routine check of oil was fine. Front axle also has fluid in it. That dip stick reads low. I cannot find in the manual what fluid goes in there so I can top off. Can any one enlighten me?
   / Front axel oil/fluid #2
I have a Boomer New Holland 20, I think it is the same tractor as the Boomer24 made by LS. My manual calls for New Holland AMBRA Hypoid 90 Gear lube. When I needed to top mine off the dealer said I could use any good quality 90wt gear oil. Keep an eye on that oil level in the front axle, mine tends to leak at the blue "pressure relief" cap even when the oil level is at the correct height.
Thanks. I will re-read the manual and see if I can find that again. I have some 90wt gear oil in inventory so that is easy peasy :)
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE VR59 59" HYD VIBRATORY ROLLER (A57193)
UNUSED FUTURE VR59...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A52707)
2017 GENIE GTH-844...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Mini John Deere Truck (A55853)
Mini John Deere...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
