Front axel chartering
   / Front axel chartering #11
Are you familiar with the front axle float adjustment screw? If you face the front of the tractor and crouch down so your eye is at axle level there is a bolt there with a lock nut. This holds the axle tight on the axle. If you lift the front end off the ground with the loader, grab the front axle and try to move it back and forth. There should be almost no play.
The manual in the maintenance section should have a section that shows how to adjust this bolt and it does say this can cause noise.
Check that out.
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
John Deere 1025R (A53317)
John Deere 1025R...
2022 KENWORTH W900 SLEEPER (A55745)
2022 KENWORTH W900...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A57024)
2014 Doyle Dry...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
