Front axel chartering
   / Front axel chartering #1
Drmcd
Kioti dk4510
I have a dk4510, shuttle shift the front wheels have a vibration/chatter at low speed. It happens in both 2 & 4wd. It is not as noticeable at higher speeds. Any suggestions as to what might be causing this and should I be concerned. Thanks
Thanks I have already checked them.
   / Front axel chartering #5
Checked what? Any maintenance history? What are the hours on your tractor? When you figure it out….let us know.
Answered the previous question: I checked the lug nuts.
Regular maintenance, oil and fluid changes.
426 hours.
   / Front axel chartering #7
Lift wheels of the ground with the bucket grab the top and bottom of wheel and see if there's any play. Also give them a spin by hand and listen and feel for any abnormality.
   / Front axel chartering #8
Could be something broke and 4wd isn't really working. Lock it in, raise it up, turn wheels by hand, rotate them.
Should the wheels rotate freely in 4wd?
   / Front axel chartering #10
If both are off the ground, yes. As you turn one, the other should turn the opposite direction .
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 LAND ROVER Range Rover (A50324)
2018 LAND ROVER...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
