From grass to Flowers?
   / From grass to Flowers? #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I’d like to convert an acre or two of our place from mowed field to wildflowers.
Kinda unsure where to start.
Should I get a plow and turn the top sod over?
Or go with a PTO driven tiller after cutting grass short as possible?
I can’t use anything like roundup to kill it all as there is a wetland protected area downhill and next to it.
It doesn’t bother me to buy the equipment, just want to get the right stuff first.
I plan on eventually expanding up to about 5 acres of a vegetable or flower crop like lilacs but still researching that for now.
Last frost is around 1May so I’d like to start soon if I have time to get ready for this year.
In southern Vermont which is in Zone 5b.
   / From grass to Flowers? #2
Might kinda hard on rototiller if land has rocks,someone near by could turn the soil over follow disk harrows remove rocks etc,than fluff soil with rototiller.
   / From grass to Flowers? #3
Doing flowers should work the same as doing a milkweed patch. I covered the grass with newspaper and then put a couple inches of mulch on top. Put the milkweed plants and seeds right into the mulch. Actually, the first year, I also put in flower seeds. Both the milkweed and flowers did fine, flowers especially that 1st year. Took the milkweed a couple more years to really populate the patch. The flowers have dwindled because I didn't keep adding more seeds back like I did milkweed.
If you plow or rototill, you'll just bring up more weed seeds.
Ralph
   / From grass to Flowers? #4
Ralph
Just curious.. Why milkweed?? Attracting Monarch butterflies or what? I get milkweed but I never heard anyone planting it.
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
Pallet Fees (A50774)
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2014 GMC ACADIA SUV (A51222)
2014 GMC ACADIA...
