Hello all,
Decided to sell my beloved Deere X585 and move up to a BX24.. Had the BX for 3 weeks now and it is awesome, although the Deere was more comfortable to sit on.. oh well, it is a tool, not a highway cruiser.
The first thing I did was put lights on the ROPS, 2 forward trapazoids and one rear flood, seperate switches. OK, I disregarded the decals for idiots that do silly things and welded the light brackets on the bar, snaked the wiring through the ROPS for neatness and drilled three 1/4 inch holes through the center of the light brackets to pull wires through. I have an engineering backround, and those 3 little holes in those locations wont do squat to the bar strength.
Rather than spend close to $2K for the Kubota power angle plow set up (and have to remove the grill guard!) I adapted my Deere plow set up to the BX24... Some steel, welding, kubota grey paint and hyro hoses.. works like a charm! Also welded on a hitch receiver to the plow frame bracket so I can move a trailer around when an implement is hooked to the rear (like the bagger).
Attached some pics ..
Am now in the process of converting a tow behind dethatcher to 3pt, fabricating a 3pt for an electric ATV spreader, 3pt ball hitch and some lift forks..
What do you think? Should I paint the plow orange? or does the yellow give the package character? Ditto for my JD Green dethatcher!
