Fried my charging circuit!
   / Fried my charging circuit! #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Fri AM jumped on & NOTHING! Checked the wiring & found the alternator wires burned & the connector starting to melt. Anyone know if the regulator can go bad & cause this kind of problem, and is there an american alternative to the regulator? It's up on the firewall and I have to take the tractor apart to get to it.
   / Fried my charging circuit! #2
The hard plastic connector on my charging circuit was old and brittle. Mine "fried" similar to what you are describing. I assumed that the connector had allowed something to short that had caused the problem. I rewired the circuit back to where I had good wire and replaced the connector with a two conductor trailer plug. Well, it still works, at least part of the time. Sometimes the charge light comes on for no apparent reason but usually only briefly. I also have to charge the battery from time to time. I wonder if my alternator might need brushes. Right now, it's working fairly well and I'm a little hesitant to tear into it. At least it isn't smoking anymore! /forums/images/graemlins/wink.gif
Mine also burned what looks like a fusible link from the starter solenoid. So, I think there may be more going on. I do seem to be getting some current from the alternator, but am fairly sure there is a short. The charging circuit is tied in to the starter circuit, and that seems to be why the fusible link blew.
Anyone replaced their regulator/rectifier.
   / Fried my charging circuit! #4
I had a YM1820 do the same thing. I replaced the fusable link and it did it again. I then unplugged the current limiter and replaced the link. That stopped it. A new current limiter did the job. I think Hoye and Fredricks both sell aftermaket limiters to fit some models.
Thanks! It sounds like the answer.
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2001 NEWMAR 45FT TANDEM RV WITH 2 SLIDE OUTS (A51222)
2001 NEWMAR 45FT...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
