Frequency of oil change in low use small engines.
   / Frequency of oil change in low use small engines. #1
garry
Ohio
JD 1050
I would like to hear some opinions on what the oil change frequency should be on low use small engines. I have heard that oil becomes contaminated with moisture over a period of time. If that is the case wouldn稚 the moisture evaporate the when the engine reaches operating temperature? I have also heard some say that oil becomes acidic over time. If that is the case why do we not hear calls to change fluids in transmissions and differentials on an annual schedule?
I have a trim mower, water pump, and a JD212 that I only use in the spring to roll the lawn. These engines probably get less than three hours use per year. The oil always looks like new. Do they really need an annual oil change?
   / Frequency of oil change in low use small engines. #2
I try to do once a year changes but my small engines get more use than 3 hours. Some equipment gets two changes like the wood splitter and 4 wheeler.
   / Frequency of oil change in low use small engines. #3
i like once a year changes...
as tot he ops question on trannies and diffy..
those don't see combustion byproducts like a crankcase does....
   / Frequency of oil change in low use small engines. #4
I have gotten bad on this class of short run time engines for sure. I know it is 5 years sometimes.
   / Frequency of oil change in low use small engines. #5
all my small engines. lawnmowers,tiller,pressure washers,4 wheelers,generators,tractor and diesel truck get yearly changes.Only about 1000 miles on my truck in a year.I do oil analysis on my diesel truck and am good for yearly changes
   / Frequency of oil change in low use small engines. #6
I try to do it yearly and most get done, but some get "missed" and go 2 years.
   / Frequency of oil change in low use small engines. #7
I change the Oil, Oil Filter, and Air Filter on my Craftsman Riding Mower once a year, right before mowing season starts. I also lubricate it and check to make sure everything is tight. I check the battery also.
   / Frequency of oil change in low use small engines. #8
If the oil hasn't gone dark, I don't worry about it for 2 years anyway. I live in a dry climate & moisture isn't much of a issue.
   / Frequency of oil change in low use small engines. #9
I've always wondered myself...
On my truck it is every 2500 miles which is once a year.
I have a neighbor with a Troy rototiller he bought new in the 70's and uses it each spring... he has NEVER changed the oil... makes sure it is topped off and lubricates the linkages... just never changed the oil...
My luck it would seize or something.
   / Frequency of oil change in low use small engines. #10
I've always thought I could tell by the look and smell if time to change. Some small engine or even unused cars go for 5 yrs or more.
Mike
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
