Frequency of greasing a MMM for BX2380
   / Frequency of greasing a MMM for BX2380 #1
corl
West Grove, Pa
2013 Kubota MX5100 HST, 1989 Kubota F2100
I have a new BX2380 and was reading the manual where it stated that you should grease the deck mower daily. I have a F2100 and the manual says to grease the deck every 50 hrs. What changed? and how often you grease your mower deck and drive shaft?
   / Frequency of greasing a MMM for BX2380 #2
Well, I do the spindles two or three times a season (May through October) and the driveshaft only if I have to remove the mower, maybe once or perhaps twice a season. I change the engine oil, filter, and air filter yearly (about 75 hours use) even though the book says it can go 200 hrs between changes. I guess that's overkill...
   / Frequency of greasing a MMM for BX2380 #3
I grease the spindles, wheels, idler, king pin every 10h and the universals at 20h.
I checked my manual and found conflicting info on grease intervals, sometimes listed as daily and other times 10h. I suspect Kubota equates “daily” with a full days operation.
   / Frequency of greasing a MMM for BX2380 #4
That's more frequently than I was planning to grease it, fortunately this cordless grease gun makes quick work of it.
   / Frequency of greasing a MMM for BX2380 #5
I recently bought a DeWalt grease gun and a LockNLube tip. I am really liking the LockNLube!
   / Frequency of greasing a MMM for BX2380 #6
I got one of these several years ago...
IR 5190.
I grease my deck every 25 hours of use.
   / Frequency of greasing a MMM for BX2380 #7
I grease it whenever I think to do it. I'm sure it's way more than necessary, but a squirt a day keeps the bad wear at bay.
   / Frequency of greasing a MMM for BX2380 #8
I give each spindle one pump of grease after each mowing which is about two hours. Probably more than is needed but it can’t hurt.
   / Frequency of greasing a MMM for BX2380 #9
I have greased the one on my BX2200 about twice a year for the last 18 years while cutting 5 acres a week in a long growing season in the Deep South. I have worn out a ton of blades and guide wheels but no other issues with mower. Still have original bearings and belts.
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2017 Jeep Wrangler (MPV), VIN # 1C4BJWDG2HL674841 (A51572)
2017 Jeep Wrangler...
New Long Forks (A53002)
New Long Forks...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
