I use anti-gel in my TC 26 DA and it still has a problem from time to time in very cold weather.. It is true that I use it sparingly in the fall so the winter finds it with summer fuel still in it. Because of the way it acts, I think part of the problem is the very tiny fuel filter/bowl on these little tractors.
The tractor always starts, and then will run for a few minutes like everything is fine, but then die. After that it will start and run for just a few seconds and then die. This is due to the small amount of fuel getting through the filter which is surrounded by gelled fuel. It never gets a chance to warm up to any extent, and because it doesn't and the fuel filter/bowl doesn't get a chance to scavenge any warmth froim the engine, it worsens. If the engine runs long enough to get to normal operating temperature, there is no problem, and the fuel filter does indeed scavenge quite a bit of heat from the engine. Probably if you run it long enough, the fuel tank does as well..
To hopefully rectify the problem, which I got out of using diesel 911, I added more of the antigel, and a little bit of kersoene and some fresh fuel to fill the tank after I used it a while. It seems to be better now, but I haven't tested it in 10 degree weather since the last time it gelled.
It's nice to have fresh fuel, but if you don't use the tractor constantly and you follow the manual suggestions to keep the tank full, you are always going to end up with summer fuel in there for at least the beginning of the winter. It's also true that these little engines don't burn a lot of fuel, so it's hard to strike a balance.
