freeze plug size?
   / freeze plug size? #11
Has anyone tried installing the "Kats 11619" or similar into a Mahindra 3016?
I don't think you'll find one necessary.
I was contemplating some sort of an engine/battery heater for my 3016, but have found it starts excellently without either. It's been below 0 degrees F here several times this winter and it starts like a champ. I'm not going to waste my time or money adding anything.
   / freeze plug size? #12
That's why I have not been a big hurry to install my Kat's heater in my 5035. Starts pretty good even with limited use of the grid heater [ I put a swich in line on mine that keeps it from firing up in the summer. ] But I have spent quite a bit of time downstate with family matters this winter, and wish I had put it in since the barn has not been heated up each day. So, in it goes next summer... and fresh antifreeze.
   / freeze plug size? #13
I installed a heater in the radiator hose of my 4035. Not because it makes trouble starting, but if I plug the heater in for a few hours before I start it, the engine starts running smooth a lot quicker. If I don't use the heater, it starts but spits and sputters for a longer time.
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
204158 (A57193)
204158 (A57193)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2006 FORD F-150 PICKUP (A58017)
2006 FORD F-150...
