Freeze Plug Blues
   / Freeze Plug Blues #1
mostly_gas
Super Member
Texas
in-between tractors
1979 Ford 1700 4WD. Last time I used it, the freeze plug between the glow plugs blew out. I bought a new set of freeze plugs, replaced the missing plug using hitack sealer during installation and about 1/16 of the land showing. I let the tractor sit 3 hours so sealant could set up. Replaced anti-freeze and started the tractor with radiator cap off and after 5 minutes or so plug#2 also left the engine. Suggestions?
   / Freeze Plug Blues #2
are you saying a newly replaced plug let go.. or another old one.
Not uncommon to have multiple plugs fail near same time if they are all same age. If i see a freeze plug with a rust hole.. I usually like to repalce all of them.. if ones weak.. the others -MAY- be as well.
post back.
if a new plug.. did you dimple it with a ballpeen hammer to set it once in place?
soundguy
   / Freeze Plug Blues
post back.
soundguy
Newly replaced plug let go. Did not dimple,have not worked with this style freeze plug before. How many dimple should I use?
   / Freeze Plug Blues #4
Is this a 'freeze plug' or 'core plug' ?
Freeze plugs are cup shaped and don't require dimpling.
Core plugs are almost flat like a coin with a slight concave/convex shape. These require dimpling.
   / Freeze Plug Blues
Ok it is a core plug.
   / Freeze Plug Blues #7
That is a great explanation Will. I will save it for future reference.
Bill
   / Freeze Plug Blues
that to all who replied to my first post. The link helped me replace the plug and mow without an early plug exit:D:)
   / Freeze Plug Blues #9
I may have the same problem, need advice. I just started my 1700 and while changing implements and letting it idle, the guage went to hot. I lifted the hool and saw what looks to be antifreeze comming from between the gas tank and the rear of the engine. My question, is there a freeze plug or a core plug there? I can not see it without taking the tank off. Where did you get your plugs?
   / Freeze Plug Blues #10
napa has core plugs.
here's the parts list.. I'd pay attention to number 3.
AR SBA110006030 ENGINE, SHORT Short Block, 1500, No Longer Serviced, Engine Assembies Include: Cylinder Block Assy., Crankshaft Assy., Camshaft Assy. & Piston & Rod Assy., Start Year: 01/01/
AR SBA110006040 ENGINE, SHORT Short Block, 1700, Engine Assembies Include: Cylinder Block Assy., Crankshaft Assy., Camshaft Assy. & Piston & Rod Assy., Start Year: 01/01/1979
1 1 Bare Block Assy., 1500, Start Year: 01/01/1979
1 1 SBA110106056 BLOCK Bare Block Assy., 1700 Includes: Ref. 2 thru 5, Start Year: 01/01/1979
2 3 SBA198466010 PLUG Plug 8.4mm , Start Year: 01/01/1979
3 3 SBA064100045 PLUG Plug, Start Year: 01/01/1979
4 1 SBA064100055 PLUG Plug, 55mm Dia, Start Year: 01/01/1979
5 1 SBA198516050 BEARING Bearing, Front, Main, Standard, Start Year: 01/01/1979
5 AR SBA198516460 BUSHING Bearing, Front, Main, .25mm or .010", NHNA Only, Start Year: 01/01/1979
5 AR SBA198516470 BEARING Bearing, Front, Main, 0.50mm or 0.20", NHNA Only, Start Year: 01/01/1979
6 2 SBA030501025 PIN, BALL DOWEL, M10 x 25 L, Pin, Start Year: 01/01/1979
7 2 SBA030500625 DOWEL DOWEL, Pin, M6 x 25, Start Year: 01/01/1979
8 1 SBA030300410 PIN Pin, M4 x 10, Start Year: 01/01/1979
9 1 SBA052300500 O-RING O-Ring, Start Year: 01/01/1979
10 1 SBA198736052 TUBE Drain, Start Year: 01/01/1979
11 1 SBA198416010 GAUGE Gauge, Start Year: 01/01/1979
12 1 SBA185246011 SENDER UNIT Sender, Oil, Start Year: 01/01/1979
13 5 SBA111136020 STUD Bolt, Start Year: 01/01/1979
14 1 SBA111136090 STUD Bolt, Start Year: 01/01/1979
15 6 SBA199376010 NUT Nut, Start Year: 01/01/1979
16 1 SBA199236260 RING Collar, Start Year: 01/01/1979
17 1 SBA110706090 PAN, ENGINE OIL Pan Assy., 1500, Start Year: 01/01/1979
17 1 SBA110706020 PAN Pan Assy., W/2WD, 1700, Start Year: 01/01/1979
18 1 87351909 GASKET Gasket , Start Year: 01/01/1979
19 14 86511315 WASHER WASHER, M8 x 16 x 1.6, Start Year: 01/01/1979
20 14 SBA011510820 SCREW, CAPTIVE WASHER SCREW, CAPTIVE WASHER, Hex, M8 x 20, G5, Start Year: 01/01/1979
21 1 412211 BOLT Screw, Cap, HH, CL8.8, M12 x 1.25 x 25, Start Year: 01/01/1979
22 1 SBA025100012 WASHER WASHER, M12, Seal, Start Year: 01/01/1979
23 1 SBA068118280 TUBE Tube, Start Year: 01/01/1979
24 1 SBA110706040 PAN Pan Assy., W/4WD, 1700, Start Year: 01/01/1979
here's the exploded diagram:
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
