Freeware Office suite software
/ Freeware Office suite software #1
bjr
Eastern WA
Jinma JM354
I'm finacially not able to go out and buy the latest and greatest MS product anymore. Anyone out there have any experience with the freeware word processing/spreadsheet software packages? I needed to do a documentand and wanted to make a table with a autosum formula in a word processor. I finally had to switch over to the spreadsheet to get done what I wanted. I was turning in some reciepts to get reimbursed and wanted a numbered bullet point table with a autosum formula to total the column. I used the Google online package and it did what I needed when I needed it done and I was wondering who else uses the freeware? Yes, I'm aware there can be some formatting issues when trying to open a "Word" document in a "nonword" package. bjr
/ Freeware Office suite software #2
The company I work for has an IT guy who loves to cheap out on us. Most of our machines have Windows Office suite. Some of the computers in Production, though, have been using LibreOffice. While I haven't personally used it, the guys who do use it every day spend most of their time complaining about it not working right (won't open, freezes for no reason, etc.). I've watched it go bad on a couple of occasions, and even once had to dodge a flying mouse. I would caution you against that particular product based on that.
I greatly dislike the new subscription-based crud for Windows Office. You actually cannot "go out and buy" it anymore. Unfortunately, it tends to work when you need it. I feel your pain, though. It's not cheap by any means.
/ Freeware Office suite software #3
I like open office, if it's still available.
/ Freeware Office suite software #4
Open Office works just fine. It is very similar to the Micro$oft Office 2003 release.
/ Freeware Office suite software #5
OpenOffice or GoogleDocs
/ Freeware Office suite software #6
We have been using OpenOffice exclusively for a few years now with great results. If you need it, GIMP is a great alternative to Photoshop.
/ Freeware Office suite software #8
Libre Office has worked pretty well for me under Linux. In fairness, I don't use it much.
/ Freeware Office suite software #10
While not exactly free, I would check on eBay for an older version of Office - 2003 or 2007. I still use 2003 on my personal computer, however I had to download an add on from Microsoft so I can view documents in newer versions of office - free on their web sight.
I also work for one the largest insurance companies in the U.S. And they use 2007 version.
/ Freeware Office suite software #11
I tried Open Office briefly probably in the 90's and found it quite similar to MS Office. If I needed a suite on a PC I'd give it serious consideration.
/ Freeware Office suite software #12
I only very occasionally need a spreadsheet or word processor and am not into shelling out for each and every upgrade which has all sorts of new features which I don't need. It's Open Office for me.
/ Freeware Office suite software #13
THIS ^ is almost certainly the reason for THIS v. Your IT guy is an idiot.
....have been using LibreOffice. While I haven't personally used it, the guys who do use it every day spend most of their time complaining about it not working right (won't open, freezes for no reason, etc.). I've watched it go bad on a couple of occasions
Libre Office is a derivative of Open Office. There really isn't much difference between them, and they are both reliable. If you are used to MS, you'll find Open/Libre Office to be different enough to be annoying, but you get used to it.
/ Freeware Office suite software #14
If google docs is working for you why change? The only issue would be that if you have no internet connection then you can't use it.
/ Freeware Office suite software #16
I'll not argue your assessment. I was just trying to be kind. :cool:
I would say a majority of said stupidity is driven by managements ideas to continue to reduce IT budgets in to dust and not give any choice. Ive seen this happen in numerous companies, big to small.
That said, Ive also seen some groups within IT make some pretty dumb choices on products and services when they've been given carte blanch spending.
Universal constant: you cant fix stupid.
