free play in bucket
   / free play in bucket #1
RobertCramer
Western Mass
I have a BX2350 and was wondering about how much free play is ok in the bucket. I can lift just the bucket by hand and move it a good 2 inches. I am wondering if something is wore to much. Any thoughts?
Thanks
Bob
   / free play in bucket #2
Bob,
The play can be either in the bucket pins and bushings, which is impossible to fix without replacing them, or the cylinders aren't full of fluid.
The second situation seems like an answer a nutcase might put forth, but humor me on this. Grab the bottom edge of the bucket and try to tilt it up while you watch the dump cylinders. If they compress slightly, you have what's called a "floppy bucket". The fact that it has a name (I didn't just invent it, really) tells you how common this is.
What happens is this: when you dump a load of heavy material out of the bucket, the hydraulic pump can't keep up with the cylinder travel (they are "driven" by the load in the bucket), and air gets introduced into the dump cylinders. Where it comes from is another question, and a hot one I don't want to get into.
If they do move slightly when you lift up the bucket lip, try this: start the tractor and hold the joystick in the full dump position for about 5 seconds after you hear the relief valve open on the hydraulic pump. It usually takes about 5-10 seconds. Do the same in the full curl position. When you're done, level the bucket and try moving it by hand again. I'm willing to bet it'll be pretty solid unless your pins are worn.
What you're doing is getting any air out of the cylinders and replacing it with fluid, which is nearly incompressible.
That's the good news, the bad news is every time you dump a heavy bucket full of material it'll cause the same thing. It's not harmful unless you need exact control over the bucket for some job.
Sean
   / free play in bucket #3
Thanks
Bob
I noticed this when testing a BX2360 with some equipment. When any of the BX buckets are fully rolled back, the arc travel of the cylinder itself rather than the hydraulic portion come into play first when curling forward. This is where I noticed the "play" I think you are referring to. The way to tell if something is wore is to exercise the bucket and specifically look at the points of interest.
   / free play in bucket #4
I need to update this because I had the chance today to test a brand new BX25. With the bucket curled back there was play in the bucket lip and it was due to entirely slop in the pins. It was more than an inch of play but I do not know if it was 2". This was at a Kubota dealer and the tractor was brand new.
Mayrath Swing Away Auger 10-62 (A50514)
Mayrath Swing Away...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2014 Ford F-550 Altec AT37G 37ft Bucket Truck (A50323)
2014 Ford F-550...
